Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: I'm still here..
  1. #21
    Feb 2009
    Reading, PA
    You can get it out through the rear passenger door. Mainly just getting the trim pieces off in the right order. There are some good you tube videos and write-ups. I got the material from Amazon through headliner doctor and the 3M spray adhesive for a total of about $65 since i had a gift card. You can get it out and take it somewhere. Probably between $200-300, might be more if you take it directly to them to take out.
    2009 G8GT Maverick Silver Premium and Sport Packages
    1998 Z28 Sebring Silver 6 speed
  2. #22
    Member BAMAGXP's Avatar
    Sep 2010
    From what I recall, you need to get the headliner in through the windscreen as it's all one piece.
    Ummmm. Come again? It can be removed through the back door, no need to remove the windshield/windscreen. That wouldn't be a reasonable solution. Haha.
    2009.5 G8 GXP SRM M6 (1 of 61), (1465 build of 1829 total GXP's)
    a.k.a. "Michele"
    GO: Kooks MID's Headers, RotoFab. Corsa Cat Back Exhaust, Texas Speed Stage 2 Cam. FAST 102
    RIDE: Pedders GSR's with the Lowering Spring, BMR Cradle and Radius Rod Bushings, Pedders Sways
  3. #23
    Sep 2010
    Quote Originally Posted by RobA300 View Post
    Yup. I bought the same material. Perfect match!
    a.k.a. "Michele"
  4. #24
    VIP Member Kermit's Avatar
    Va. Beach, VA
    COOL! Thanks for the info guys. I only have sagging at the front edge and back corners. Would it be best to try to just respray with the adhesive or just redo the whole headliner?
    2009 G8 GT MGM.
  5. #25
    N.O.LA
    Mine failed similarly. I used 3M adhesive in a red can from HD almost 2 years ago, and I had to redo the same spots in the front last month.
    JAM
  6. #26
    Senior Member JAFO's Avatar
    Sep 2013
    Newberry, SC
    Dropped home Internet, too cheap for a decent cell phone with data BUT work finally quit blocking this site so I'm back.
    151k... How do you NOT drive your cars??? Would kill me not to be able to drive mine.
    --Brian--
    2009 Pontiac G8 GT
    2008 Chevy Impala SS--Traded 4/1/2021
    2016 Dodge Challenger R/T Plus
    2001 GMC Sierra
    GODSPEED CHARLIE!!! R.I.P.
  7. #27
    I had the whole headliner redone last year at a local auto trim shop. It started coming down in the rear corners by the back window and then other sections began drooping.
  8. #28
    VIP Member matts88yj's Avatar
    Nov 2011
    Lancaster, PA
    Just stopping by to say hi. Been a while since I've signed into the forum. Have done a fair bit over the past year and currently have the dash half way apart putting in the 5 gauge pod that I got from Crazy Paul years ago. I got tired of collecting parts and decided to start installing the stuff. Ironing out some wiring details and then it's assembly time.
    - Matt
